Lower intake manifold torque specs for aluminum heads?
  • Lower intake manifold torque specs for aluminum heads?
    Talking about the bolts that bolt the lower intake manifold to the head... Are they the same torque specs as the stock heads/manifold? Putting a systemax on afr 185's.
    18ft lb
      18ft lb
      Gracias!
        My pleasure, go over them like 5 times until they stabilize.
          AFR suggests you don't even put a torque wrench on them. Just hand tight.
          You certainly need to go back and retighten a few times.
            My hand tight is usually way too tight, I'd stick with a tq wrench, be sure it works at those low tq specs or do 216 inch lb if you have an inch lb wrench.
              Next time you should hand tighten the bolts with the hand you do not jack off with, I'm sure it won't be as strong...
              Originally posted by stevo
              Stevo
                truth
                  lol. speaking from experience?
