'01 LS1 T/A. I replaced the fuel pump due to it going bad. The previous owner let it sit for ~5 years. I then replaced the filter and drained almost all of the old fuel out. Then, I put in a few gallons of premium. After cycling the key 5-10 times, there is no pressure in the line. It'll fire and run for 3 seconds or so and then shut off again. Also, I can press the Schrader valve after cycling the pump and pretty much nothing comes out at all.
'01 ls1 trans am no fuel pressure
Just as I posted this I had a "duh" moment. I hadn't checked the regulator yet, so I set that as tomorrow's goal. Pump runs just fine, so I know the solenoid is good
Keeping my hopes up for the FPR...I really hope the lines are somehow gummed up.Originally posted by BuzzoSome dudes jump out of airplanes, I fuck hookers without condoms.
Originally posted by crapstang View PostJust as I posted this I had a "duh" moment. I hadn't checked the regulator yet, so I set that as tomorrow's goal. Pump runs just fine, so I know the solenoid is good
