I just picked up a Megasquirt thats set up to not run a MAF but the harness I'm running is for a MAF foxbody. I'm going to be modifying the harness to work on my 66 but should I use a SD harness instead of cutting the MAF section out?
Engine harness
Do you have a pin map for the megasquirt? It should be a direct plug in with a separate harness for the map sensor.
Map should only need a sensor 5v reference, sensor ground and then the signal return. You may even be able to use the fox maf 5v and ground already in the harness and re-pin at the ecu plug for the signal return.Fuck you. We're going to Costco.
