Just got my pushrods in, wanted to double check the length. Converted 2 lifters over to solids, put 2 rockers on with zero lash & no preload, and turned the motor over a few times.
One of the rollers is not centered on the stems... and the wear pattern is heavier on one side as opposed to right in the center. Keep in mind, this was no pre-load. And so far I've only checked cyl #1...
87gt, afr 185's, e303 cam.
Thoughts? (I'm new at this so I'm still learning!)
