Yup, that's for 2. I've seen the 9's around $190ea, and the 7's & 8's around $180ea.
...and agreed a little pricey for a plain steel wheel....but they look killer on the right car, and I'm thinking in this case could have a good look for a 4-door. Paint them blue to match the interior.
70' Chevelle RagTop (Forever Under Construction)
Guess I was too late. Barpn, I just clicked ur CL link and it says it's expired. No clue what it was.
Secondly, question. The car has a dual electric fan setup yet only one side spins (driver side). I have yet to see the second fan kick on. I assume it's for like the ac being on. But i think I need that second small fan to keep her cool. Drove her to work tonight. First longish drive since I got it. She ran around 170-185 while cruising. But if u stop, it slowly creeps past 200 in a fairly short amount of time. Thoughts? And fyi, it isn't hooked up to a thermostat. It just runs as soon as I key up the car. Previous owner hack job. But he did a decent job at keeping it fairly clean looking and also using some fused relays.
Could the second one just be on a T-stat, or are they wired together?
Also, if you don't have a shroud, when you creep or stop, engine heat will go right around the fans. Remember my set-up? Same deal.
She was pretty low on coolant so that might be the culprit.. Anywho I finally figured out this dumb shifter contraption and I think this ol hoopie might give a prius a run for its money. Jus sayin...
JD at Pro 1 Autosports in Arlington, currently holds the world record for an LS based Gen 5 Camaro running the 275 tire class. He currently has an early Buick Skylark and a Gen 1 Camaro in the shop undergoing LS motor transplants.
