Ok guys, I got some good datalogs this past weekend.  I have a few areas I want to try and understand.  I'm attaching a snapshot of my log and I'll have to give you the values to understand.
Black line is RPM
Green line is Fuel Pressure
Blue Line is Boost Pressure
Purple line is AFR.
The first thing that jumps out at me is the shift points and rpm drop. The 1-2 shift took place at 5850 and the rpm only dropped to 5140. The 2-3 shift took place at 5740 and the rpm dropped to 4180. Looking at the a spreadsheet I've got for gear ratios in the tranny, etc. I was suprised to only see a small drop in rpm on the 1-2 shift. This is an AOD.
Secondly, you can see the fuel pressure taper off at the top even though boost was still coming up. I think this is my fuel system maxing out. Agree?
You can also see evidence of the fuel system issues on the AFR line. It goes from about a 10.8 at the 2-3 shift all the way to about a 12.0-12.1 right before I shut it down. Most of 1st and 2nd was hovering around 11.5 or so.
Thoughts?
					Black line is RPM
Purple line is AFR.
Thoughts?
