Caterpillar 3406e ECM wont turn fan on
I will call them. And I gained mileage with the tune. Just getting theOriginally posted by racrguy View PostI don't think that'll be an issue. I remembered the name of the place, it's called Truck ECM. you might call him and ask what it'll take to fix it, and if it'll have to be reflashed. Best I recall we've never had to flash one after getting it back from him.
Question: why do you have it turned up so high? That HAS to be killing mileage.
right turbo and cam cost to damn much
Hayden makes a couple of fan controllers, oreillys generally stocks them. One uses an 1/8" npt thread temp sensor, the other a probe that goes in the radiator fins. They both have a provision for a/c control and are adjustable via rheostat on the unit. I've used the coolant temp sensor style on 4 different projects now. It has a relay built in and wired to control 2 fans if I remember correct, but I've always used it to control a higher amperage relay since most of these have a taurus fan on them. In your case I assume it will be controlling the fan air supply solenoid.
There is no timer function on the a/c control, however, it will cycle the fan on anytime it receives an A/c input, unless it's running through a pressure control switch.
ya it sure is nice to pass empty trucks going up hillOriginally posted by Tx Redneck View PostDude, 900HP on a 3406e? That's BALLS!
but it dose run a little warm up mountins
i went up i-17 from phonix to flagsaff half throttle at 50 MPH weighing 80300
but i was running 60 but couldnt keep it below 218 degrees
