Question on N20 w/ window switch and 2 step
  • Question on N20 w/ window switch and 2 step
    Just added a 2 step to the car (09 GTCS) and was wondering what the RPM setting differences needs to safely be between the launch controller and the window switch (which activates the N20 kit) to keep the N20 kit from spraying under launch control.
    The N20 kit is pulling ohm reading from the TPS for WOT. I don't want the car to spray when the 2 step is doing its job as I prefer to keep the intake, and the hood, on the car and out of the dumpster.
    That being said, what should the minimum RPM setting difference between the 2 step and the window switch be? For example, if I want to launch at 3,500 and set the window switch to activate the N20 kit at 3,800 is that enough of a difference to prevent the kit to fire under launch control?
    Appreciate your thoughts on this.
    300 rpm is pretty safe but wouldn't it be just as easy to wire it where the launch control activation switch disables the solenoids?
