air bag guys inside
  • air bag guys inside
    I am getting ready to begin fabbing up a 4 link with air ride on the back of my c10. I am having trouble with trying to decide what pressure I should run in the bags at normal ride height for daily usage. Been getting anywhere from 30 lbs to 60 lbs. What are you guys running and how is the ride? going off the chart i located for the bags i am running (dominator 2600's) it seems based off the weight of the rear of my truck and the installed bag height (5-6 inches at normal ride height) i will need around 30 lbs. I have never messed with air bags before so any input or advice is appreciated.
    As long as you don't over inflate the bags you ride at whats comfortable and plenty of ground clearance. If you need to put too much air in to raise it due to a bad design it'll ride like poop.
    Pro-Touring Build
      Get in touch with CRASH on the board.
      63 Fairlane
      Originally posted by forbes
      i call 1911 first then 911
