I currently have a Mark VIII fan (18"), brush fan in 1990's technology. I know that CFM on high speed is around 4,800. The fan is a two speed fan and brand new old stock. So I should be able to see those CFM numbers.
With the new Holley Dominator EFI, I have the option to run a PWM fan. What are the thoughts on a Cadillac Turbo SRX Radiator Fan? They are 20" and brushless and I can package that to the radiator even if I just get a taller radiator.
I am having a hard time finding the CFM on full pulse for the Caddy fan but in watts (I think this is right) it is 850w whereas the Mark VIII is 350w on high.
The Caddy fan pulls 70amps on full tilt and that is not far from what the Mark VIII pulls on high speed 60-70amps start up but the Mark VIII only pulls 25amps in run on high (from what I am finding). Eitherway, I am running a 200amp alternator and free to wire it however I need to.
The car is the Cobra and cooling is very important to me so I can keep A/C on it and possibly a heat exchanger for the air/water water. I going to go back to 93oct and away from E85 so I am expecting higher coolant temps than I had before. That and once the temps got over 200* and I kept driving it would hit 215-220* from what I am sure was just pure heat soak in the engine bay.
Add for a regular CRX fan
Here are some pics of one I found on Lateral-G
Keeping the 17.5" tall radiator I have, I can use the fan's overhang to cover a heat exchanger like this.
