Here is my distribtion block:
The brake line fittings use a 7/16th wrench to remove (not sure about the thread pitch, it is very close to 1/8th pipe but no dice). I went to Lowes/HD and bought fittings but nothing seems to work.
Does anyone sell a T- junction that goes from whatever thread pitch these fittings are with a 1/8th pipe fitting for my Painless pressure switch?
I figure the easiest way to do this is just put a T-in right at the output of the dist. block and have it screw into to the dist. block, have the brake line that screwed in to the dist. block screw into the T and then have the pressure switch also screw into the T.
Thanks!
Thanks!
