It's not often that I get stumped, but this one is kicking my ass. Here is the story.
I have an 00 Sierra 4WD with 200K miles on it and a 5.3L engine. It was low on power, had crap MPG, and I have the codes P0300, and P0303. Random multiple misfire and cylinder 3 misfire detected. When I first got it, the plugs and wires were old, so I changed them out. Also did compression tests and I am seeing 150ish PSI. Spark tested the coils and they are firing.
The fuel pressure was reading 43 psi at load, so I changed the filter and the pump, now priming to 55PSI and idling at 50 PSI. Some people say this is too low, but I have done a lot of research into this and it appears to be normal. FPR has no fuel in the line and the PSI shoots up to 58 when the line is unplugged. Clamp the return and fuel pressure is at 70lbs. Checked the LT trim levels on fuel and they were up around 20.
I checked for vacuum leaks, didn't find any, but I decided to change out the intake gaskets anyway, just to be sure. They looked like they were leaking pretty good, got it all back together and the LT trims are sitting at 5% now. Much better, but the misfire remains. O2 sensor voltage is jumping from lean to rich, so it should be working right.
Unplugging the MAF causes it to stop misfiring, but the MAF is reading .70lbs/m and a Hz test on it showed nothing irregular. This makes me think that I'm still having a vacuum leak somewhere, but I can't find it and the fuel trims are fine.
Cliff notes:
Multiple Misfire. Checked/changed:
Compression
Coils
Wires/plugs
Fuel Pump/Filter
Intake gaskets
Fuel Trims
Ohm checked injectors.
O2 sensors
MAF unplugged stops misfire, but tests OK.
Cliff notes:
Compression
Coils
Wires/plugs
Fuel Pump/Filter
Intake gaskets
Fuel Trims
O2 sensors
