1990 GT Convertible - full weight, will probably relocate battery to the trunk and have a sub in the trunk in the future.
I want it to hook up well on the street, ride well on the street, look good, and most importantly not rub the tires on minor bumps.
Right now it sitting on Eibach drop 1.5" drop springs, 17" cobra R's, Nitto 275/40's on the rear 255/40's up front. The drivers side rear tire is getting into the fender to the point where it's cutting up my brand new tire on mild bumps. Passenger side is doing it too but it's minor in comparison.
Did it worse when I took 100 lbs worth of my little girls around the block in the back seat.
I want to do coil overs just on the rear for now and hopefully eliminate the problem.
What height spring and spring rate should I run?
