I'm only getting about 3/4" of travel in my front suspension. If I measure, then jack the car up and let the suspension hang i'm measuring just over 3/4" travel. That just doesn't seem right. Car has AJE K member, stock A arms (not binding) strange adjustable struts, and strange coil over kit. Also has SN95 spindles. Also look at how high the strut is coming out of the caster camber plate, should I try and put a spacer on the bottom to get more length underneath the plate? I could lower the front end some to get the travel but that is going to throw off the front/rear balance and its already raking down in the front as it is.
weight on suspension:
no weight on suspension:
setup:
setup:
