Weird idle issue 2002 GT
  • Weird idle issue 2002 GT
    Got an 02 GT 5spd that has a mild cam LT headers and CAI. Motor runs good and everything feels fine but when ever driving it it idles high.
    Start car idles around 700 RPM. While driving the car wants to stay at 1500 RPM and will even accelerate without pushing the gas until it reaches it. Put the car in neutral and coast and the car drops to about 1500 RPM and stays there for 10-15 seconds (or until the car comes to a stand still it seems) then drops back down to 700. if you rev it it sticks at 1500 again then drops again.
    If the car is in gear and you let off the gas it feels like it is still getting gas and after about 10 seconds you can feel the cars idle drop and it begins to slow down. (like when you use the engine to brake and downshift)
    Hopefully that makes sense and I didnt ramble on to much.. Any ideas what would cause this? Had someone tell me it is the cam. but not sure.
    IAC valve needs to be cleaned.
      This. My Mach 1 did the same thing.
      It's very easy to do.
        Yeah, two 8mm bolts, some carburetor cleaner, and a Q tip.
          Tried Cleaning and did not fix the issue. Decided to replace with a new one and still has the same issue.
            Try to relearn the idle.
              hey everyone i have a problem with my car idling, the other day i cleaned out my throttle body. Since i cleaned out my throttle body my idle seems to be a bit to high. when i'm stopped at a light the idle will hang around 1400 rpms, for 4-5 seconds then drop down to about 800 rpms. I have a bbk...
                Who did the cam tune?
                  intake leak
                  Be honest, even if it hurts.
                    I believe the guy said Gearheads did it.. But it may have been Dallas Mustang
                      Check everything mechanical like has been stated in this post - intake/vacuum leak specifically. Then give me a call and I'll get you fixed up
