Needing some help/advice. I have a 08 Bullitt and I removed the dual pod gauges that came with and put a stock pillar in. Only thing I did was disconnect the plug in from the obd2 port and pull the cable through. Now the issue
I noticed the reverse lights stay on and the car won't start. I have power (the headlights, interior lights, brake lights, and alarm lock/unlock all work) but the car doesn't even click. The theft light flashes at the normal 2 seconds and not rapidly. Also I no other cluster lights come on (like the odometer, engine light, etc) and I have no power to the radio or windows. What could this be?
Cliff notes: have power/headlights but no radio/windows/instrument and the car wont start, not even click.
Update: I just hit the panic to see if it works, the panic works but I couldn't turn it off/disable the alarm. Had to pull the battery to stop it.
