Best way to clean oil off parts
  • Best way to clean oil off parts
    What is the best way to clean oil off a transmission, underside , and misc parts ?
    I plan on pulling transmission this weekend and i want to clean it all up while its out.
    Thanks,
    Brake cleaner.
      solvent is cheaper.
        Brake cleaner is what I use.
          I recently used some oven cleaner and let it sit overnight. Holy shit, that stuff worked great.
            Simple Green or Purple Power concentrate and a nylon bristle brush
              I figured brake cleaner ... its not petroleum based right, i could clean a part, tac and paint ?
                Ive used that too, but I quickly sprayed it down with a pressure washer.
                  If it's really dirty, you're going to spend a lot of money on brake cleaner. If you want something in a can that will actually cut the grease, hit it with Berryman's.
                  I use denatured alcohol to clean residue before painting. But not to clean the grime. A tool for every job IMO
                    True... think about how a trans looks. lots of grooves... whats the best approach in your opinion ?
                    I was gonna load it up and take it to the car wash.... What should i use as a pre-clean to break up the oil ?
                    I really need a steamer ..
                      Simple Green or Purple Power concentrate, then hit it with high pressure soap
                        Simple green and the car wash is what I do on big stuff.
                          If you clean the bell housing, watch out.
                          1 high pressure shot into the housing and you'll have a face full of shit.
                            lolz
                              LOL ..... im going to try to avoid this !!!
