Well, Bought my motor!
    Originally posted by jayjohnson600 View Post
    Is that an Aluminum block 4.8L ?
    Can you provide details on price and vendor you got it from?
    I have been considering an aluminum 4.8L for my daily driver Miata.
    Sending you a pm. its cast iron
    2012 GT500
      Originally posted by white88 View Post
      Blasphemy!
      Not everyone can do it the right way, sir.
        Originally posted by snacksnack View Post
        why 4.8 and not a 6.0?
        A couple reasons. Firstly I was looking for a clean, new, low mileage motor. For the money the 4.8 was it. The 2007 up 4.8 comes with stronger rods and makes almost the same power as the last gen 5.3 (295-305). It has perfect compression for boost as well.
        2012 GT500
          All the 4.8/5.3's went aluminum blocks in 2010 or 2011 I think, just gotta search. They are more $$$, but usually lower miles.
            That one does look clean. Its nice they took the time to pull the harness for you.
            The LC9 (aluminum 5.3) is in some of the 08-09 trucks as well.
              I got ECU, Wiring, Alternator even down to the 02 sensors and gas pedal assembly
              2012 GT500
                Can I get that info as well? Thinking about taking the 455 out of my car and am curious what something like this actually costs.
                Originally posted by Sean88gt
                As always, my criticisms should never be taken as if I wouldn't go balls deep in it.
                  Sent
                  2012 GT500
                    That is good. If you dont mind me asking what did you pay for it all?
                      I would never do that to a Cobra..or any mustang! But good luck!
                        I was trying to stick to the golden rule of never posting what you pay, but I've gotten 10pm's already so I'll just post it. $1200+250 freight to my door
                        2012 GT500
                          I never thought I would either. But it is the smartest option. See what kind of mustang/cobra motor you can find for $1200. Most likely a mark 8 motor with 190k on it that will last 2wks with 10lbs of boost. This way I've got a low mileage motor that will hold up under boost with very little mods. and get 25mpg highway
                          2012 GT500
                            Did you think of resale value? Not many want a 4.8 swapped Mustang
                              it will have turboz though!!!
                              I let this car go once and was lucky enough to get it back. It definetly will not go anywhere again.
                              2012 GT500
                                Will you have to remove any of the AFM/DOD parts before you boost it?
