Im working on a 78 Datsun with a l20b 4 cyl that wont start. New carb, fuel pump and coil. A friend of mine bought this truck from a guy that left it in a field. The cylinder head looks pretty new so Im guessing that the head was replaced and they couldnt get it to start so they parked it. Iv checked the timing/firing order 3-4 times, Iv ran the valves and re-checked them. the only things I can find wrong are that there's no ballast resistor and low compression. If I crank it long enough the engine starts to fire but it back fires and has fire pop through the carb. I squirted oil in all 4 cylinder and compression went up to 120 so Im guessing the low compression has to be the culprit? I took the valve cover off and the cam and the crank line up. Iv had engines with low compression that have started and ran ok but never one that had 90psi and wouldnt start.
Thanks.
Thanks.
