Annoying noise
  • Annoying noise
    Trying to figure out what this noise is. Anyone have any ideas? Coming from the engine bay, 2003 Cobra. Any help is greatly appreciated.
    Thanks
    Found another video of same/similar sound.
    sounds like a whiny power steering pump.
      x2. Does the tone change much when you crank the wheel?
      Originally posted by Buzzo
        Sounds like your Naynay is loose.
          Could also be the damnittsteve bearing.
            I haven't noticed any changed in tone when cranking the wheel. Would an idler bearing make that noise on its way out?
            Thanks
              Yea I was wondering about that...
                X3 on the PS pump
                  No change in pitch when the wheel is cranked.. When sitting at idle and turning the wheel it changes just due to the fact the rpm drops just a bit which changes the pitch.. Not your normal PS Pump sound if you were running low on fluid and turning the wheel..
                    Put some Lucas power steering treatment in it. If it quiets it down, then you have a ps pump that is on the way out. It doesn't have to be low on fluid to make noise.
                      I'll give it a shot, Thanks
                        Idler pulley.
                        Some cars and a bike...
                          Ended up being the tensioner pulley on the SC side. Pulley came off while going back to work. Appreciate Noah over at Precision Mustang in Forney for getting to it really quick and getting it back on the road.
                            Nice Cobra!
                            GOD BLESS TEXAS
                            August Landscaping
                            214-779-7278
                            Seb's high class.
                            He'll mow your grass.
                            He'll kick your ass.
                            He'll piss in a glass!
                              Nice Cobra!
                              Thanks!
                              Sent from my iPhone using Tapatalk - now Free
