Rear end knocks in gear and under load (when giving it gas) The faster i go the faster the knock is and also get slightly louder with speed. It's gotten a bit louder over the past year. Most likely needs a new pinion bearing/crush sleeve and to have dialed in correctly...maybe some other stuff idk. I know there are probably some pretty knowledgable rearend/ differential people on here I could possibly take it to (I'm on a tight budget). If someone could point me in the right direction I'd greatly appreciate it! Thanks in advance - James
Also it's an 86 T-top Foxbody with a 1998 Gt 8.8 rearend. Carrier was rebuilt with new clutches and 3.73 gears etc etc about 4 years ago.
