Aeromotive a1000 external help
  • Aeromotive a1000 external help
    Took a long hot summer trip. On the end of the trip my a/f gauge was 1 point more lean than usual. Now on short trips under throttle it leans out and i am experiencing fuel cut. Gonna order new filters but does anyone have experience with these pumps. Pressure is good at idle and pump sounds the same as it always has. No fuel controller as of yet but i will get one now regardless.
    At 40 psi that pump should do roughly 700 pounds of fuel an hour. So do a flow test and figure out the gallons per minute.
    Originally posted by soap
      Mine works great. 10 feed 8 return lines. 60lb injectors. Its also used..
      Doug
      90 LX Coupe 5.0
      90 7up Vert. 5.0
        Mine is a complete set up from aeromotive. Sumped tank to 42#ers. Do you daily yours and highway drive it?
