Have a chance to buy a t5 for my conversion. Numbers on the side is a c 2605803. Story on it is it was traded for work. Guy drove mustang to his shop and they pulled it and motor out. Can someone hopefully inbox me what a good price is for this is with only knowing that. He says its a 3550...
t5 numbers and price help
Originally posted by elongoria View PostHave a chance to buy a t5 for my conversion. Numbers on the side is a c 2605803. Story on it is it was traded for work. Guy drove mustang to his shop and they pulled it and motor out. Can someone hopefully inbox me what a good price is for this is with only knowing that. He says its a 3550...
91coupe i am going to look for that when i go look at it tomorrow. but i amgoing with tools in hand to get it then if it is. just wanting to know what i should be willing to spend if the numbers are what he said they are and it is a 3550...
all i am gonna say is yall would cry if you knew what i am gonna give for it. i may not even go to sleep when i get off work just to make sure i get it. it is still mated to the engine. Does anyone know what exact tools i need to get it apart? What clutch do i get for it if i need to get a new one?
Originally posted by elongoria View Postall i am gonna say is yall would cry if you knew what i am gonna give for it. i may not even go to sleep when i get off work just to make sure i get it. it is still mated to the engine. Does anyone know what exact tools i need to get it apart? What clutch do i get for it if i need to get a new one?
Deals are to be had, just don't get to worked up and end up with a t5.
You'll need a set of 3/8s drive metric sockets and wrenches, grab 1/2in drive too if you have it. You will need an assorted extensions and 1 or 2 swivel joints. If used like 18-24 inches of extensions depending on how I'm doing it.
Take a saws all if just in case his exhaust is welded.
Grab a break over bar too.
You may need 2 1/2 or 13mm wrenches to undue to clutch cable.
If you're not a haas. Get a 12pnt 12mm socket for your 1/2 or 3/8s. (For the drive shaft bolts)
7/16s wrench for the speedometer cable.
And anything else you think you may need. But that should do it.
