I replaced the battery in my 93 GT today. Yes, it was the correct battery and connected correctly. When it was connected the alarm chirped and all appeared to be well. The problem occurred when I went to start the car.
I disarmed the alarm, got in, and there was no power when I put the key in to start it. At this time some smoke also appeared behind the battery in the vicinity of the ECU. I'll point out some time passed between when the battery was connected and the smoke since I was tightening the terminals. It appears to be directly related to disarming the alarm. There is power getting to (some of) the car as the under hood light comes on and the car will chime with the keys in the ignition with the door open. No gauges, fuel pump, etc when the key is turned though.
So what did I do? I'm guessing the alarm blew when I disarmed it but I'm not sure if that would cause all of this. I looked at the wiring in the area and couldn't find any obvious damage or smell anything burnt. This is literally my first experience with a fox body so I'm not sure what I'm looking at/where/if the alarm would be wired into this area. Anything else that could have blown in that area? I checked the fuse box and everything looked good there. The car ran normal prior to this.
