The brake switch isn't being pressed. It's been keeping the lights on. I put three pennies in between the switch and the bracket, lights turn off. Is there supposed to be something in the opening of the bracket?
The switch would go right though the opening of the bracket. There's no budge on the bracket. I had the same issue with my clutch switch relay but I replaced it and bent that bracket down. I'm reading about the bracket having a stopper??
Originally posted by talisman
Originally posted by AdamLX
Because fuck you, that's why
Originally posted by 80coupe
nice dick, Idrivea4banger
Originally posted by Jester
Look on your floor. If it happened recently you should see peices of in there.
Shouldn't be more than a couple buck from Nissan.
I had to order some from Honda for my 99 recently. Was like 1.80 or something.
Or just smooth off the top of a bolt and throw a nut on it. I've done that too. Just make sure it's not out of adjustment and keeps pressure on the brakes.
Or duct tape and those pennies you mentioned.
95 Nissan. I did find some broken plastic and now that you've mentioned it its probably what broke off the bracket. Stupid vatozone doesn't carry it, they had no clue what I was talking about. I guess the dealership will be my next stop. I don't want to rig up anything.
imports are bad about this, they have a little rubber (or it used to be before it turned into a hardened piece of brittle plastic) button that hits the brake switch, clutch switch, cruise cancel switch, etc. Easy fix is to take a standard 1\4" bolt or metric 6mm bolt (usually has a 10mm head) and put the bolt side against the brake switch button and nut the back side. I've fixed many a car that way.
That's probably what happened to my clutch relay switch a while back also. I ended up replacing the switch and bending the bracket down so the switch would hit. Thanks for the idea. I'll hit up home depot tomorrow.
