Originally posted by racrguy
no oil pressure after changing head gasket!!! why??
Originally posted by greenbullitt View PostMike there is no passage for oil through the hg
Dropped the op driveshaft.
Lol but, oil still goes to the head from the block, through the gasket??or is that just drain?
Edit; LOL yeah... Oil gets up there via pushrods right?Last edited by 91CoupeMike; 08-09-2013, 05:25 AM.
Originally posted by 91CoupeMike View PostAh I was thinking cooling/ flipped gasket.
Edit; LOL yeah... Oil gets up there via pushrods right?Interested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
I have an oil pump shaft bent in the middle to 45 degrees as a little token reminder of this issue...
90's 5.0 in an 84 mustang. The oil pump shaft did not have the little blocking ring that the one I replaced it with had. It looked like this part was in place to keep the shaft from falling down into the motor.
I could not get it with a magnet...had to drop the pan. If your lucky and/or it has that ring on it then it may still be sitting tilted in the shaft.2004 Z06 Commemorative Ed.
Originally posted by 91CoupeMike View PostI was thinking that, my friend had added a vacuum pump to his bracket car and it dropped time. How does that work? Why wasn't mine super badass? Haha
Originally posted by Kart21 View PostOil pump shaft sounds like.
Pull the sending unit off and crank over the motor WITHOUT starting it.
Should see lots of oil squrting out, if not, pull the Dist. and see if you can see the top of a 5/16 hex shaft.
Thats the oil pump drive shaft or it should be.
Hopefully you didn't hurt the rod / main bearings running w/o oil pressure.
use a Huge magnet to slide the pump shaft around to the oil drain plug hole to get it out. That if its in the bottom of the pan. Sometimes it will hang vertical in the motor. Pull the pan then.
Been there. It sucks.Ring and pinion specialist
Damn it !
Strongly suggest getting an aftermarket shaft as the factory ones tend to twist.
Some, and I can't remember who, make a 5/16 hex on both end and a 3/8 main body driveshaft. They are the best. Extra good if you are using a high pressure / high vol. pump.
Might think about a windage tray install as the pan is off. Cheep horsepower.
Don't forget to put the little retaining ring on the shaft, as talked about before, to keep the shaft in place when you pull the dist. out next time.
Good luck.
Good luck.Ring and pinion specialist
Originally posted by greenbullitt View PostarpVortex rear stand $75
8.8 410s. $50
**SKAGG NASTY**
1990 Foxbody GT for that ass
114 door
13 FX2 White 5.0
Originally posted by terryd001 View Postok so I got the new shaft with the retaining ring installed, my question is when I drop the shaft in does the ring stay on? cause now my distributor wont go all the way inInterested in being a VIP member and donating to the site? Click here http://dfwmustangs.net/forums/payments.php
questions, I never ran a vacuum pump
Originally posted by racrguy View PostYou have to account for it, it takes a worked over oil pump to overcome the affects of the vacuum,
but I never ran a vacuum pump. am I thinking right on this?Don't worry about what you can't change.
Be honest, even if it hurts.
