i have a 85 fox body with a 2000 5.0 in it. I blew a head gasket about a month ago and put new head gaskets on fired it up and have a lot of chattering at the rocker arms. well I noticed I don't have any oil pressure. im guessing that why I have the chattering going on. but why would my oil pressure go away from changing the head gaskets?? please help!!!
no oil pressure after changing head gasket!!! why??
 I had similar issues after my h/c/i.
 I had to much vacuum on my crankcase, you could take the oil cap off and hear it sucking in air over the exhaust, it was causing the car to not idle when it was warm, and when the rpm dropped i would lose oil pressure causing chattering. I took off the oil filter and noticed it was full of oil and wouldn't pour out.
 Reduced crankcase vacuum and changed the filter and went on.
 I had pvc vacuum and a vacuum hose going to the oil breather port on the oil filler neck, which is a no no apparently.
 You know I did hear a sound (like a socket hitting the ground) when I was setting the timing. And my gauge is afternarket but everything's hooked up as it should be. So I should be able to see if the oil pump shaft it there by removing the distributor??
 Oil pump shaft sounds like.
 Pull the sending unit off and crank over the motor WITHOUT starting it.
 Should see lots of oil squrting out, if not, pull the Dist. and see if you can see the top of a 5/16 hex shaft.
 Thats the oil pump drive shaft or it should be.
 Hopefully you didn't hurt the rod / main bearings running w/o oil pressure.
 use a Huge magnet to slide the pump shaft around to the oil drain plug hole to get it out. That if its in the bottom of the pan. Sometimes it will hang vertical in the motor. Pull the pan then.
 Been there. It sucks.
 Lol, vacuum pumps can make more horsepower than just normal crankcase breathing, but the rings and oiling system need to be designed for it.Originally posted by 91CoupeMike View PostI had similar issues after my h/c/i.
