Help with C.E.L. codes please
  • Help with C.E.L. codes please
    CEL came on a few weeks ago and I need to take care of this before state inspection expires.
    This is on a '09 Volvo S60 2.5T. Codes are as follows:
    P030
    P2251
    P0135
    P053
    Any help will be highly appreciated.
    Sent from my SPH-L710 using Tapatalk 2
    --carlos
    Originally posted by projectPONY View Post
    P0030 - HO2S Heater Control Circuit Bank 1 Sensor 1
    P2251 - O2 Sensor Negative Current Control Circuit/Open
    P0135 - O2 Sensor Heater Circuit
    P0053 - HO2S Heater Resistance
    Bad O2 sensor or loose harness connection at the sensor.
      All those codes point to an O2 sensor? Do they say which one?
      --carlos
        Bank 1 sensor 1 according to the first code.
          Yep front bank 1 according to alldata
            Here's the main issue, Volvo only releases generic specific dtc's to the public, not the manufacturer specific codes. I ended up buying a special Swedish vida code reader because the snap on couldn tell me enough. If you want you can use my bsr, you r even adjust the heated seat temp and wastegate settings if its aspirated.
            Ded
              Thanks for the offer, I'll keep it in mind. I just bought the o2 sensor and will be installing it tomorrow. If that doesn't fix my issue I'll let you know.
              --carlos
                Did you fix the your car? I seen it jacked up to the sky the other day. LOL
                04 GT
                91 LX
                  Lol, yeah I got it fixed. Damn O2 sensor was a PITA to get to.
                  --carlos
