Does anyone here know a place were I can get custom ac lines. I have a 1992 mustang with a coyote swap that needs ac.
Help with ac line
Air pro in Mesquite. I haven't been by there in a while but they used to build lines for us.sigpic
2004 GMC Sierra, tuned by Sam
Originally posted by StephenFUCK!! im gay then
Originally posted by Codered View PostDoes anyone here know a place were I can get custom ac lines. I have a 1992 mustang with a coyote swap that needs ac.
Get your fittings and hose first. Go home and lay it out on the car. Cut the hose to the length each section needs to be then put the fitting on the hose. Mark the alignment of the hose to feral to fitting. It is important you mark it since the hose is not going to twist to the angles you need otherwise.
Last year I built a complete A/C system from scratch for my 94/95 car. Nothing off the shelf would work and all said and done, it is perfect.Fuck you. We're going to Costco.
