Current set up lasted about 2 years, it was a center force df pressure plate and a Veleo clutch disk from az. It was a temp fix as the df disk only lasted a year.
As of late, it's been slipping after a gear change at wot but not any other time.
So I'm taking it apart.
I have a lot of abuse on the flywheel, should I surface it, or replace it? Would the pressure plate be alright or just replace it with a stock az clutch set?
Not aposed to an aftermarket set but I'm not sure how long I'll be using a t5.
