2006 ford f150 lariat tail lights, brake lights and turn signal went out
  • 2006 ford f150 lariat tail lights, brake lights and turn signal went out
    maybe somebody on here has had this problem, I was driving down hwy and cruise went out, didnt think much about it the next day blinkers and taillights went out. I replaced brake switch that is hooked to brake peddle. I replaced turn signal multifunction switch and no difference. I obviously checked fuses under passenger side dash.. I need some help please
    KODFWS 2011
    Hmm, if the cruise went out, I wonder if the clock spring behind the air bag has anything to do with it? Is the air bag light flashing? This might be a long shot but this is similar to what happened to my '94 back in the day.
    Sent from my SPH-L710 using Tapatalk 2
    --carlos
      Ground wire broke
        which ground wire and where you think it is
        KODFWS 2011
          Just a thought bc i had a lot of weird issues after breaking a ground wire headed to my door. If its the clock spring in the steering wheel there was a recall on the 06s for something like that.
            FFind a wiring diagram and see what is shared by those 3 circuits, and start your diag there.
              thanks man i will start my search
              KODFWS 2011
