anyone drill and insert screws for rims
  • anyone drill and insert screws for rims
    I have some mt et streets that dont hold air that well I was told I could have holes screwed into the rimsand screws put into the tires to keep them from spinning off the rims I seen a set for sale on here but dont know how good or if thats a good thing to do
    What psi are you running? Have you tried a bead sealer yet?
      inflate with air and check the sidewalls with soapy water.
      bead sealer will help, but what kind of 60 foots we talking about here?
        I havnt gotten thst fsr if I air them up by the next day they have lost a good amount of air I dont want to spin the tire off the rim at launch
          I don't think I've ever had a slick not loose a few pounds overnight. Unless brand new.
            They seemed better since I actually drove around on them last night
              Slicks are poarse. Don't store them with air, and lay them flat,
                if you have tubes in them they shouldn't lose much (if any), i can easily go a week(s) without much of a drop at all in mine (and they are FAR from brand new)
                  I need to get some tubes soon
                    Jegs sells a tool for marking the rim and drilling. It's only about 5$.
                    If you run tubes, you will absolutely have to drill the rims. Drilling now is optional. Slicks will lose air with our without screws. some are worse than others.
                      You could just use straight dish soap to coat the inside of th tire. Works pretty well and really cheap.
                      903-870-8109
                      Thank you:
                      2JM Diesel & Fabrication - for the chassis and tuning
                      Freak Show Performance - for the great transmission
                      Jimmy Patton for the pit help
                      Chris Fowler for the motor work
                      TRZ Motorsports - thanks Mike
                      NRC Motorsports - thanks Bob
                      Team Z Motorsports - thanks Dave
                      Forced Inductions - thanks Jose
                      Work Turbochargers - thanks Reed
                        Thanks guys and brooks ill be out monday to show you the car
                          Slicks are poarse.
                          porous*
