power steering hose
  • power steering hose
    How can I get this off. It seems to be a 16mm wrench, but my wrenches have disapeered. I tried using channel locks, but that but is sift and it flattened it. I'm stuck, I'm putting the rack in and need to replace these hoses too. This one is holding me up.
    If you need to replace them, can you not just cut them?
      To be honest, without the correct tools for the job, it will be hard to complete the job. Aside from a crescent wrench, I can't think of anything that would work other than the correct sized wrench.
        I can tell you that you don't want to over torque the swivel connections. If over tightened they will leak.
          if you do not have a line wrench, it sucks to be you. Once the edges got rounded off, you entered Hell.
          Good visegrips are next
          Some cars and a bike...
            yep
              Got it off, but it broke off in the fitting. Took the fitting off the pump to try and get it out. Looks like I need a new fitting now
                Manual Rack? lol
                  Those fittings are soft metal, and you will likely have issues if you don't use the correct tool.
                  I usually use a line wrench(must be the correct size) plus vice grips to keep the wrench from spreading out.
                  Autozone has some fittings on a tube stub, that might be a direct replacement.
                  Jay Johnson
                  Car hauler for hire
