Boosted High Horsepower Motor Oil?
  • Boosted High Horsepower Motor Oil?
    Just bought a YSi to put on my Dart 347 and was contemplating whether I need to run a heavier oil. Ran 5w30 synthetic in my old 500hp 306 but thought if I end up making 700+rwhp, maybe I should reconsider what to run. What's everyone's recommendations? I've heard Mobil 1 15w50 is good for this application and some friends recommended Valvoline VR1 20W50. What say you?
    Sent from my not soo far away Galaxy...
    1988GT DSS pro bullet 306,pp track heat heads, pp downs box intake, TFS stage II cam, S-trim 13lbs, 503/461
    2002 VTX 1800C Chopped and Raked
    2000 F250 4x4 PSD
    2012 Ford Exploder
    www.fquick.com/payne5757
    www.myspace.com/payne5757
    Rotella T6 5w-40, I road race a turbo car with it, been great. Oil temps have gone over 300 w/o issue, but I don't recommend oil temps that high
      Ford gt calls for 5w-50.
      I'd suggest something similar.
        I tan vr1 20w50 in my blown 347. Great stuff
          That is what I run in my truck. It is okay okay in a gasoline motor? Anyone else ever done this?
          2000 F250 4x4 PSD
          2012 Ford Exploder
            I use it in my boat(330hp 350), and have since it was new with zero issues.
              I run valvoline vr1 20-50 turbo car...
              81 LX
              82 GT
                someone told me that the VR1 still has the zinc/phosphate mix in it
                  Someone told me that in 2007 zinc was taken out of most/all oils??
                    This, I have run Rotella T since my turbo fox in every car I own. It still has zinc, 1400 ppm I believe.
                    Ded
                      Is run some sort of synthetic 20w-50 oil.
                        I've found a lot of people singing praises for T6. I think that's what ill be switching to.
                        2000 F250 4x4 PSD
                        2012 Ford Exploder
                          Correct me on this one but I read the heavier weights are better for the turbo, not necessarily the motor
                            The heavy weights help protect the bearings under high stress environments buy giving a nice thick cushion between the bearing and crankshaft journal. I'd the oil is too thin, the film gets broken and you have raw metal to metal contact and failure is the ultimate result.
                              From what I understand, its the resilience to break down under high heat conditions that make an oil good for turbos.
                              2000 F250 4x4 PSD
                              2012 Ford Exploder
