Picked up a short block and 347 parts.
  • #31
    I bet by the time this engine is built he
    1 welded 2 rod journal oil ports
    2 left the valve train of of said cylinders
    3 ends up with a mean loping 6 cylinder v8
    • #32
      Early stages if cylinder deactivation. Beeotch!
      • #33
        Originally posted by Clifton View Post
        Stroker motors are overrated.
        A 351 would do work. I just want to keep the short deck height. I really don't want a cowl hood. I know there are ways to make it work though.
        • #34
          Originally posted by junk racing View Post
          Shit compression makes the turbo spool quicker...mines 11.1 lol
          I know. Compression and boost make for badass engines lol
          • #35
            ask anybody with a blower on their new 5.0 lol
            2011 Mustang GT
            • #36
              Originally posted by shumpertdavid View Post
              Depends on combustion chamber cc's. My new regal pistons have a 14 cc dish, they will yield me a 10:1 compression ratio with the headgasket thickness I have and the factory 46cc combustion chambers. I'd guess yours and a 62cc chamber would still make fair n/a compression ratio
              Those pistons with a 347, 58 cc heads will net him around 9.8:1 ish cr.
              • #37
                347>351 every day on a NA build. With exactly the same hci, the 347 will smoke it because of the smaller mains.
                Full time ninja editor.
                • #38
                  I'll give you 60.00 for the pistons and rods then you don't have to find matches.
                  • #39
                    I wonder
                    what is the HP loss with 3" mains versis the 302 size. the reason svo went to the smaller size was because of the surface speed at high rpm on long duation races. I wouldn't think there would be much if any hp difference under 7500 rpm. Oil films don't generate much friction. Nascar is a totally different animal, they shoot for any weight and hp difference and go to extremes to get it, like running a rod 3 grams under weight.
                    Be honest, even if it hurts.
                    • #40
                      I would think a 331 would be a better street engine over a 347, or am I wrong?
                      The shorter piston causes more oil consumption and due to the rod pin it has more blow by right?
                      Not ideal for forced induction, but badass with nitrous?
                      • #41
                        That 351 turns into a 408 though =)
                        1993 Vibrant Red Cobra #1741.
                        • #42
                          The newer 347 stuff Is much improved over the old. It all depends on the end goal. n/a, spray, boost.
                          • #43
                            More than you'd think.
                            Top dollar 351 based strokers use cleveland mains with spacer bearings.
                            • #44
                              are you in here, again?
                              • #45
                                Dude, just stop. Seriously.
                                There is something to be gained by the 4.030" bore of a 347 unshrouding a large-ish intake valve as compared to the 4.000" bore of a 351. But even most mildly built 351s are gonna be at that bore size anyway just due to normal rebuild practice.
                                At that point the big differences between the two are the taller block and thicker deck of a 351W, the better rod ratio of a 351W, the better head sealing of 1/2" head bolts of a 351W, and the stock 1/2" main bolts and beefier main caps of a 351W. Oh yeah, the "power robbing" 3" mains, lol.
                                A Windsor with the same heads and cam will make the same power and be cheaper than a 347. If you build it with comparable parts it will last a decade longer too. And there's room for another hundred cubic inches when you're ready to spend some money on it.
