Any ford techs here able/willing to tell me where all the major grounds are for this heap? I need to start tracking down some electrical issue with the car.
Intermittently, but very often, all the dash lights and gauges just go bat shit crazy while your driving. I've already replaced the battery and an alternator test come back good. I've found some info online that says it could be the instrument cluster, alternator, loose ground, or voltage regulator which some online posts suggest the voltage regulator for that car is in the ECM, but I can't find a solid answer to verify that.
Any help is greatly appreciated. The wife took a video of the craziness, if I can find somewhere to host it, I'll post a link.
**edit**
Actually, this is pretty much the same thing except my car does it more often, it causes the AC and radio to turn off and also chimes every time it happens. I also forgot to mention that I also sent the cluster to be repaired by some guy in OK(found him on ebay).
[ame]http://www.youtube.com/watch?v=sErKhJV8ED8[/ame]
**edit**
