Originally posted by CWO
new motor is in: does this sound right?
Originally posted by CWO View PostI'm just a tiny bit insulted that you don't think I thought of trying the screwdriver trick. I'll get pics up eventually, but needless to say that didn't work..... neither of the 4 times I tried on different parts of the filter. I ultimately had to cut the filter at the base and use a pair of vise grips attached to the base and pry against those with a long screwdriver little by little. It was ridiculous. The filter barely resembles a filter anymore.
So are you expecting me to run that gauge all the time or just to check it? I mean am I going to have to by a gauge pod and whatever else too?
As for that oil pressure gauge, you can use it as a test port with a parts-store oil pressure gauge or install a permanent gauge and check it there if need be later on, either way you prefer.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by DON SVO View PostHey, you installed the guides backwards and then followed it up with (apparently) cranking an oil filter onto a new motor with an air chisel! Don't get all pissy with me for questioning your oil filter removal methods!
As for that oil pressure gauge, you can use it as a test port with a parts-store oil pressure gauge or install a permanent gauge and check it there if need be later on, either way you prefer.FWIW, Brent put the filter on. Don't think I'm not going to stab him in the neck the next time I see him.
I'd prefer to just use a gauge to test. At least for now.
Originally posted by CWO View PostHey! They looked the same to me, besides I've never installed them before, I've changed my oil a few times.FWIW, Brent put the filter on. Don't think I'm not going to stab him in the neck the next time I see him.
I'd prefer to just use a gauge to test. At least for now.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by CWO View PostIt crossed my mind.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by CWO View PostWe were all stone sober during this install, surprisingly. The rest is probably fairly accurate.Originally posted by PGreenCobraI can't get over the fact that you get to go live the rest of your life, knowing that someone made a Halloween costume out of you. LMAO!!Originally posted by Trip McNeelyOriginally posted by dsrtuckteezydont downshift!!
Originally posted by CWO View Postthe filter after trying the screwdriver trick but BEFORE the vise grip trick.
I had a factory FL400 on my daughters truck that was put on by king kong himself at Ford. It took me two hours and a trip to the auto parts store to get it off. I have a contact at Ford in Dearborn, I found my way to an engineers office and told him to suck my dick and hung up!
It just made me feel, well, better after that call.Originally posted by SilverbackLook all you want, she can't find anyone else who treats her as bad as I do, and I keep her self esteem so low, she wouldn't think twice about going anywhere else.
