Ok, sooooo I have an 88 F150 w/ a 302
Yesterday after redoing the timing cover to fix an oil leak, this damn truck did something VERY odd and I can't figure it out.
It did it once before also.
So while it was idleing in park letting all the air out of the cooling system it was idleing fine no issues. Temp was good and all was well.
Then the RPM's slowly started to go down. And it shut off.
Now here is the issue: go to restart and it dies. Try to restart again and dead to the world. No lights, no radio, no nothing. Check battery and full 12+ volts.
Let it sit for a while and turn key to ON: lights work, radio works, everything ok. Go to start, "click" and DEAD again. Nothing works at all.
Let it sit overnight and try it this am before work. Exact same. Lights come on, radio works, dome light on, and when I turn the key it shuts down.
Full voltage coming off the starter solenoid, battery good & full voltage.
Any ideas and what and where to check are GREATLY appreciated!
Also checked fuse box and all fuses are good.
Thanks in advance!!!
