Compression check on a cold motor
  • Compression check on a cold motor
    How much difference will it make in the readings if it's a cold compression check?
    Looking at an 800hr boat motor, everything else on the boat looks mint (not restored, just extremely well taken care of).
    my suzuki g10 will show ~20lbs difference between being cold and warm.
    i have heard of people using a spray bottle with some oil in it to spray in the plug holes to simulate an oiled engine for compression tests. also dont forget to do the test WOT or i believe you'll get low numbers.
      Spraying oil in the holes will give you a false reading.
