I'm having some trouble out of my Msd ignition system intermittently cutting out. It won't kill the car but will pop through the exhaust. It's acting like it is dropping signal for a brief second. I have ohmed the pickup shows good, tested the coil shows good, substituted a new coil and tested the box....I'm stumped....anyone had a issue like this
msd issue
My 6al would cut out once it warmed up.... but the engine would die and not start for a few minutes until it cooled off ( sometimes less than 5 minutes....other times it would take 10 min to restart). I posted up on the MSD tech forum and they fixed my 8 yr old box for free under "warranty". If I remember right it was a resistor. Maybe you have one starting to go bad?
It was a b*tch to narrow it down to the box because the problem only presented itself when it got warm enough and it was intermittent. The box always tested good.... except right when it did it. If I did not test it IMMEDIATELY when it happened then it never showed problems with their tests.
I also had issues with blowing blaster 2 coils. MSD asked how I had it mounted and then sent me a free Blater 3 Vibration coil. I have mine mounted to the engine block. (When the coil would blow it would leave me sitting and the only fix was a new coil on it...so it was an entirely different issue than my intermittent problem).
