So, it's a long going issue, but I'll try and make it brief.
I got up with a buddy of mine who has a company that wanted to try out a new MAF for my car. Anyways, we got it on the dyno and they started the car. It was running like crap, and come to find out they forgot to plug in the MAF. No big deal, I just wanted that in there so that EVERYTHING is out there. Maybe it could have made a difference. Anyways, we plugged it back in and it started up fine. The tuner had a tune that he though would be safe for the new (experimental) MAF. Made first pull and it was breaking up at the top end. Second pull confirmed that. This was on a relatively new set of plugs. But based on the recommendation of the tuner, we switched them out again. It was still breaking up, so he said that based on his experience it was probably a coil pack (although I wasn't throwing a code for a misfire). So, we ordered a full set of coil packs. I replaced them and it didn't do anything for the problem. At this point, it started cutting out completely like it was running out of fuel, and it was random but it would totally fall on it's face. I hadn't changed anything since the last dyno session except the MAF. I was asked to drive with the new MAF to test drivability of it.
So, I datalogged the car, and the FPDC was at .5. The tuner said that was maxed out and the car was out of pump. Hard for me to wrap my head around because nothing had been changed since the last pull where the fuel was adequate for the power that I was making. But, regardless, I had a set of Stealth 340's sitting on a shelf in my garage that I had been planning on putting in. So I did. Didn't change anything at all. Still cutting out at random RPM's. And just so I'm clear, it only seems to be under WOT that it's an issue. But I've never gradually wrapped the car out. The Stealth pumps seem to act a little weird from watching the PSI, but it never dies or anything. And I can watch the PSI and it will drop once I go WOT, and then pick up and then fall off completely. So I think it's a fuel delivery issue. I've replaced the FRPS, no help. I'm honestly at a loss and frustrated with the car.
By the way, the car is an 04 cobra with a 2.6L KB. Fore rails with 60 lb injectors. FRPS delete and twin Stealth 340 LPH pumps. I have a KB BAP and the dual FPDM upgrade. Car made 606/540 last time it made a good run on a dyno.
So much for keeping it brief, but I REALLY would appreciate some help with this issue. It's been since early fall that it's been jacked up.
EDIT: I can go with lethals return setup, but I really don't want to spend a grand on something that I really don't need. I don't foresee myself trying to make much more power than where I'm at now, so if this setup will work, than I'd rather stay with it. I just am to the point that I just assume rip it out and start from scratch.
