So I got a set of poly bushings for the front control arms, new poly isolators, and a set of Eibach sportline springs to replace the SVE set that didn't sit level. I figured since I don't have the money to go coil over yet, or replace the arms with tubular units I might as well replace the bushings while I have it torn down.
That said, I have everything out of the way and have the bolts loose on the driver side but the bolts go into the arm from the outside in. The nut was on the inside behind the spring. I didn't think much of it till I realized the steering rack was in the way of the front bolt and I can't get that out to get the arm out. So... I pulled the nuts off the front of the steering rack but it doesn't want to move much and I can't just pull it off the front easily to give clearance to pull the CA bolt. Am I missing something with the rack? Isn't it just the two bolts on the front where the bushings are? And I guess if there's no way to simply slide the rack forward like I had planned on I should go ahead and order/replace those bushings too? That brings up the next question, offset or standard?
