I know you can undo the tube and go that route, but i think it will be easier to just drop the tank. When you drop the tank what all do you need to undo? The tank obviously only has to move a little bit, is there enough extra line to just slide it over?
97 GT, gas tank grommet installation
Once you undo the gas tank straps and the little brace for the fill tube you can slide it over and down. The only thing that needs to be taken off is the EVAP line once the tank has dropped down a little bit.'93 Cobra-Coyote Powered
'13 Dodge Cummins
'14 Rubicon X
Originally posted by zachary View Postwhich line is that?
On new edge cars it looks like this
'13 Dodge Cummins
'14 Rubicon X
