Turn signal Help
    Biggest problem is I can't find where one of the wires goes to?
    And if you see the pic, a couple of the wires are spliced (badly).
    So trying to trace wires is extremely difficult as I'm not sure WTF I'm looking for?
    So when I get a new relay, what plugs into it is??????
    I have to do some junk yarding for some interior trim pieces so I will see about yanking a new fuse block while I'm out there.
    86 SVO
      Push it down to turn left. Pull it up to turn right.
      Oh damn!!! That's what I was doing wrong!!
      86 SVO
        Unbolt the block, and see if there's a wire coming off the back not connected. I was suggesting that you plug the new relay in exactly as the current one is, and see if the signals work. All that really does is confirm that the relay was bad though, I wouldn't just call it good if it does work.
        Get the junkyard fuse box and all of the wiring behind it, replace, and plug the relay in where it belongs.
        Even if you locate a wiring diagram, you'll still end up with wigger-rigged wiring. Replace it all like the PO should have done.
          I would plug a new relay in, however the jack ass took the wiring out of the back of the block the the relay would have plugged in!!!!
          That why I was trying to trace down wires I can't find.
          So hopefully a new block with the wiring intact will help solve my issues.
          Good thing I got this truck CHEAP!!!
          86 SVO
