lincoln brakes and rotors
  • lincoln brakes and rotors
    im needing to upgrade my brakes on the coupe. i have found a complete set of lincoln brakes and rotors basically brand new. i will be going with manual brakes as well. So i will be needing v8 spindles, i currently have 4 cylinder spindles on the car now. if i put the lincoln brakes on the car with v8 spindles will i have wheel clearance with bogarts. or should i just buy spindles and just new v8 stock brakes. looking for someone to guide me in the right direction
    I believe you are referring to me. Yes you can use with bogarts with a very thin (5/16) spacer. Ill throw those in too if you want. Yes, you will need v8 spindles. I ran this combo as a manual setup as well.
      I have v8 spindels
        I've got a complete set of lincoln rotors, v8 spindles, calipers, pads, etc. These were takeoffs from my '91 that someone had done a 5-lug conversion on. I went with cobra brakes and don't need 'em... shoot me a PM with an offer or come check 'em out first. I'm in Allen.
          ease up homie! Hes already looking at my setup! :bBishope:
            Ive seen this play out before...
              I didn't even see your post GB! LOL!
                i figured as much lol..
                  I also have the setup you're looking for... Not to be a dick, just sayin.
                  Originally posted by stevo
                  Stevo
                    now everyone calm down. We dont need to be showing up at each other's front doors here...
                      You can't be scared all your life.
                      I've got this same setup in my shop right now also.
                        Who was scared?
                          Who was scared?
                          I was!
                          Have you seen Paul topless?
                            I was!
                            depends: have you seen him bottomless?
                              im just doggin ya lol
