What spark plugs to use in brodix heads?
  • What spark plugs to use in brodix heads?
    • Spark Plug Starting Points:
    * CHAMPION C63CX or AUTOLITE 3922
    Thats what brodix calls for. I can't cross reference them at work. I'd like to run a Ngk if possible.
    And those are not available at Autozone.
      Google is still your friend...
      NGK Stk#1095 NGK Part# BCPR7ES-11
        Is that going to be the correct heat range?
        The 1095 is the same as the other number you posted. Theyre heat range of 7. And are special order.
        Would an autolite 2923 work?
          Fucked if I know. I just gave you the NGK numbers. Yeah, they are the same. One is a STOCK number, one is a PART NUMBER.....Most parts people, you can give them either number and they know. All depends on how they stock their inventory.
            Mike, get the 3922s. If you are stuck on the NGKs then just get the 1095. They both have a heat range of 7. The 3923s are one step hotter.
            1993 Vibrant Red Cobra #1741.
              Sweet! Got it all ordered and on it's way.
              Should be done like, now.
                Just thought of somthing critical, I need or would be better off with a non projected tip plug. Those listed above are projected.
                Any insight?
                  e3
                    Originally posted by Stanger View Post
                    e3
                    Not sure if serious..
                    Not sure if trolling...
                      Split fire...lol
                      2003 f250
                      1990 mustang gt 347 t56
                        Do those heads use a short thread plug with a tapered seat or the long thread with a metal gasket?
                          The plugs I use in my Brodix heads are the ones with the metal gaskets, I use AR52's.
                            They are gasketed plugs.
                              I find this thread really funny considering you're a parts guy, hahahaaa.
