Transmission help.
  • Transmission help.
    Swapped transmissions in my 2000 muntang v6 yesterday and tested it for the first time today and it wont shift by itself and Speedo not working. Is it a sensor that is making it not shift? If so which one? Trans was out of a 03 and put it in my 2000. Could this be the problem?
    Originally posted by Yale
    I want to give her a colonoscopy with my tongue.
    I'd swap out the sensors from your old one. You also might need a new tune from a transmission shop to reprogram it. I'd call some ebay junkyards like MPS in Georgia to see if it's a direct fit also just to give you peace of mind?
      check to make sure harness is plugged in correctly
