Never ending tranny problems
  • Never ending tranny problems
    I found out the issue with my trans not engaging. It was the clutch...the shop that swapped in the 2nd transmission failed to tighten all of the bolts, so only 3 were holding it in place, allowing it to torque. The piece where the splines meet the clutch was turned about 30-40 degrees off after it was pulled.
    I sent a tr3650 I had in the garage to a reputable local shop (Wilson Auto) to be refreshed. They ended up putting in new 1st and 2nd gear syncros in it.
    I also purchased a new clutch cable, clutch assembly, Ford pilot and throwout bearing, and a new pro5.0 shifter.
    After it was all together in the car, 3.17 quarts of syncromesh were put into the transmission, the clutch was adjusted properly, along with the shifter, and it ran great. For a little bit.
    About 30 miles after it was back up and running, I shifted to second gear and I had a little grind. I never had shifted it hard yet, and I took it even easier on it. It's now bad enough it's back to how that 2nd gear syncro was before the rebuild.
    1st gear never scratched on me before, but now it does.
    What in the hell happened? I'm going to drop by the shop that did the rebuild on it, but before then is there anything I am missing?
    Originally posted by Buzzo
    Could be adjustment on the clutch.
    Two in the pink and one in the stink
      TL;DR
      Learn how to drive.
        Stop going to those kind of bars!
          I'll double-check the cable, Jetboat
            T(y)ranny!
              I would just take it back and say its not right.
                That's what I'm going to do tomorrow. There's always something I can miss, so I figured I'd check with DFWM first.
                  Went to Wilson Auto today and got my money back.
                    Someone is missing something here.
                      definitely. I'm just glad they made it right...i don't care if they knowingly made a mistake, I got my money back, so no complaints.
                        lmgdao, best thread title ever.
                          syncro mesh why? I have only used atf in all the thousands of mustangs i had never had any issuse's Noah at Dallas mustang has always done my tranny rebuilds never had a issuse.
                            I did a previous 3650 fluid change and put in synchromesh...it made it perform much better. I think the tremec engineers recommended synchromesh when they issued the recall on the crappy 3650 transmission and told everyone that they were overfilled from the factory.
                            How much would your guy charge for a 1st & 2nd gear syncro change?
                              Call Noah @ DALLAS MUSTANG 214 349 0991
                              Tell him i sent you.
