i am putting stock ones back on my car. the side of the control arm that mounts to the rear end slides over thin mount with a hole in it. since that mount is about half an inch wide but the control arm is about 2 inches across. is there something that goes in between all that
upper control arms
Originally posted by TEAMJACOB View Postthe two sides that are going to slide over the mount are further apart than the mount is wide. also on my car, i dont have that bushing that is picture in above. is my car suppose to have a bushing there
Originally posted by Mysticcobrakilla View Post^^^ that's a s-197 uca. Not even close to a fox
Originally posted by dville_gt View Postyes, you should have a bushing of some sort (either rubber, urethane, or spherical)
Originally posted by CWO View Postmissing that rubber bushing in the rear end explains it
'93 Cobra-Coyote Powered
'13 Dodge Cummins
'14 Rubicon X
Originally posted by dville_gt View Postyes, you should have a bushing of some sort (either rubber, urethane, or spherical)Originally posted by CWO View Postmissing that rubber bushing in the rear end explains itOriginally posted by TEAMJACOB View Postok now to find one of those
http://www.summitracing.com/parts/fms-m-4050-b1991 5.0 Mustang LX-Hatch, BBK Cold Air Intake, BBK Headers, BBK X-Pipe, Flowmaster 40's, HPM C/C Plates, Cobra Sway-Bar, UPR Subframe Connectors, UPR Control Arms, FRPP Aluminum Driveshaft, FRPP "C" Springs, FRPP 31 Spine Diff, Moser 31 Spline Axles, FRPP 3:73 Gears, Tokico Blue Shocks, King Cobra Clutch, MSD Ignition, Taurus Electric Fan, BBK Gripp Shifter, & More
