Looking at e85 carbs. From what I have researched my fuel system should be able to run it. Anybody have a certain one they like? Also do you run the same amount of fuel pressure as regular gas? Any other things I need to watch out for while running e85 with a carb?
E85 carb questions
There's a million things to consider - but you can bet that an off the shelf carb will only get you 'close'.
Your fuel pressure will be the same, or very close to it. The only difference bieng the added demand on the fuel system once that thing starts moving some fuel - is where most pumps falter. Not sure what you're using for a pump, but even 500HP requires a fair amount of fuel. That pump should be able to support something like 650HP on gasoline to safely work with with your doing.
